Viewing 8 reply threads
    • #22516
      oz
      Please help! What is every bolt?
      I drained the oil from bolt 1 and everyrhing seems to be working fine but I read that it is the wrong drain!
    • #22518
      oz
    • #22522
      1 & 3 – For gearbox area, so you got lucky!! _ Ignore them next time.
      Drain Oil using #2  in the picture
    • #22525
      oz
      1 & 3 – For gearbox area, so you got lucky!! _ Ignore them next time. Drain Oil using #2 in the picture
      so the fact I drained from #1 is ok?
    • #22532
      If the gearbox is OK and running, then don’t touch it again.      You got very lucky!  – Most owners who drain that #1 hole end up with all kinds of issues and have to rebuild the bike again.
      You’re lucky!
      Stay on #2 going forward ,  like this tutorial
      [How to Tutorial] How to Change Oil & Oil Filter on Hyosung GV125 GV250 GT GT250R GT125R
    • #22535
      oz
      If the gearbox is OK and running, then don’t touch it again. You got very lucky! – Most owners who drain that #1 hole end up with all kinds of issues and have to rebuild the bike again. You’re lucky! Stay on #2 going forward , like this tutorial
      https://hyoriders.club/forums/topic/change-oil-filter-hyosung-twins/embed/#?secret=4mrMwvDP6M#?secret=Gxb5pQYMV0
      so why does #1 exist though?
    • #22541
      It has a spring, and washers and a sieve in there, it is purely for the gearbox cam shaft, because there is small parts there, so easier to service it after a rebuild, this is something of a concern for engine builders or garages rebuilding a damaged engine.   It’s just an overengineered engine to be fair.
      So general riders are told to just focus on #2 for oil changes.
    • #22544
      oz
      It has a spring, and washers and a sieve in there, it is purely for the gearbox cam shaft, because there is small parts there, so easier to service it after a rebuild, this is something of a concern for engine builders or garages rebuilding a damaged engine. It’s just an overengineered engine to be fair. So general riders are told to just focus on #2 for oil changes.
      what you speak of is all the #3. On #1 there is no spring and no camshaft pin or anything
    • #22545
      From the official diagram.
