Leave a review ⭐if you enjoyed the 520 set on the chain kit page , we appreciate it and glad its doing what it says 😉
Show us a picture of the dash soon when you get the chance so we see what’s going on.
If it went from 28K, to 30K but you only did 10 miles ? – – It might be an issue with the speed sensor , so take it off the front wheel, then get “PUTOLINE RACE GREASE” , dress the whole sensor with grease (go crazy) , now it should be greased and shielded from any road debris for a while , hell even wet nature too.
Open the “headlight cover” or the “fuel tank is to be lifted” , locate the 3pin plug for the speed sensor
- Clean it with Contact Cleaner
- Add a “tear drop” of ACF50 (only!!!) inside the plugs , even your dash plugs under the tank , so it gets shielded from corrosion and the like.
- No WD40! 🔥💀⚰⚱
