- This topic has 4 replies, 3 voices, and was last updated 4 years, 6 months ago by
♠️ M77.
Apr 23, 2022 at 11:06 AM #7435
Andy KerfootParticipantHello everyone. New member here, and I wonder if anyone can help me?
I have a 2007 GV250 and it has been stood for a while. I put in fresh petrol and had the battery on charge, so it’s full.
On reconnecting the battery and turning the key, nothing happens, not even a click. It’s as though the battery is dead, so I checked it again and it read 13.4V. I tried a power pack and the same thing happened. However, the horn and indicators all work.
When we had the high winds a while back the bike blew over, it was on the main stand but I had a Stormex cover on the bike and I think that acted like a sail!
Could that have caused my problem? If not, has anyone any idea what could have gone wrong?
Thanks in advance – Andy
Apr 23, 2022 at 1:55 PM #7439
SimonParticipant- Check the main fuse first
Apr 23, 2022 at 10:06 PM #7453
♠️ M77KeymasterAs per simon too.
Unhook the tank and check the right hand switch unit is fully plugged in or check the connectors did not get dirty (get halfords contact cleaner for that)
Also open the right hand switch unit, look at the contacts for the “start” button and the red “Kill Switch” button incase water somehow got to them
While the tank is still exposed, check there isn’t a “Side Stand Switch” (not all older GVs have it). If you see a switch under the kick stand, cut it and throw it away.
Join the wires (going to the bike harness) , waterproof them hard with tape as rains will TRY to get to the wires.
Check also the “clutch handle bar” , there is a switch behind it and follow its wires, you will see it connected to the bike harness somewhere near the airbox or inside the headlight cluster. Don’t bypass it.
Get a meter, set it to ohms , squeeze the handle bar in and out, to see if the switch works. The meter says zero if the switch is dead. Replace the switch.
Usually the CDI (depends if its got 3 plugs or 2 plugs) will check that the rider has squeezed in the clutch before starting (it is a good safety feature, in VERY rare cases, i mean rare, the gearbox spins even if bike is in NEUTRAL, when you let go of the clutch, the bike jolts forward and cuts out, or forbid it jolts and falls down). You can always be sure its real neutral by pushing bike back and forth or just spin the back wheel if it has a center stand.
May 6, 2022 at 11:01 AM #7542
Andy KerfootParticipantHi again – thanks for your suggestions.
I just thought I’d do everything suggested – sprayed contacts with cleaner & then WD40, disconnected sidestand switch and hey presto! It lives!
Thanks again people.
ATB – Andy
May 8, 2022 at 9:50 PM #7609
♠️ M77KeymasterHi again – thanks for your suggestions. I just thought I’d do everything suggested – sprayed contacts with cleaner & then WD40, disconnected sidestand switch and hey presto! It lives! Thanks again people. ATB – Andy
You are welcome sir , thanks for updating us all , have a safe ride 🙂
