Viewing 4 reply threads
    • #19982
      BikeShed25
      Got a bike in the shop recently and has no spark
      still cranks over and fuel pump primes
      owner has changed coils and no change, have checked all usual culprits
      side stand switch was mangled so I traced it and bypassed it, no change, codes present were Ignition coil 1/2 low circuit and crank sensor, checked crank sensor and no metal on pick up and stator is t burnt.
      thinking it may be ECU but I usually work on Jap/German/British stuff
      any ideas or common faults, I see they use the same coils as some of the Lexmoto cruisers
      thankyou 🙏
    • #19984
      Simon
      Well it’s going to be a fuel injection one I assume, with the stator burned out the rectifier is almost certainly toast until that side is sorted it’s going to be a nightmare, if the voltage isn’t correct then the ECU will just play up.
    • #19985
      BikeShed25
      Auto correct
      stator isn’t burnt and reg looks ok
      it just won’t spark at all
    • #19986
      Simon
      Have you tested it?
    • #19991
      Auto correct stator isn’t burnt and reg looks ok it just won’t spark at all
      Hyosung regulators have always  (even the chinese £10 clones) been smoking the bikes or causing all sorts of cvharging issues.
      An ECU is not cheap  or possible to acquire right now, it doesn’t take much to fry it as Simon said.
      If you intend to keep her for long, this will be the most important – numero uno – investment on the electric side of things.
      [Regulator Upgrade Part – GV125S ]
      Test your stator as simon says and report back the readings.
      Use this as a guide  (ignore that it says GT125,  the instructions apply to all Hyosungs as they still use 3-Phase stators):
      Simon knows enough ,  go with what he says if i don’t reply. 👍
