Viewing 2 reply threads
    • #11995
      Nemogreen
      I just finished installing new injectors on my 2013 efi gv250, after reassembling the bike I’ve gone to start the bike and found no dash lights, tachometer, or speedometer  and the indicators aren’t working any ideas?
    • #11997
      Simon
      Check the fuse would be first thing, the connection for the above is behind the headlight would be next.
      • #11998
        Nemogreen
        I’ve checked the fuses under the seat, and checked the connections under the cluster behind the light, a lot of fuel had spilled I’m wondering if I have shorted something out
    • #12002
      Simon
      There should be a main fuse like 30amp somewhere that’s the one that would knock out everything
