Viewing 5 reply threads
    • #8476
      Scott
      Hi,
      I ride a GV650 Aquila 2008 and struggling to find a part. Hoping someone can help find this or maybe an alternative.
      The part is the rear brake hose that runs from the back wheel and connects under the centre of the bike.
      I’ve only Sen one and its on ebay but based in the USA so delivery is expensive and takes a long time.
      Thanks in advance
    • #8477
      Simon
      Just measure it check the end fittings & find one the same length loads of after market braided hoses out there.
    • #8478
      Scott
      Thanks Simon but the fittings are different on each end which is causing the problem in finding them.
      The length is about 800mm but any that I’ve seen all have the same fittings.
    • #8489
      Simon
      Looking at the parts diagram it appears to have a metal pipe in the middle if you can see how it routes you might with a bit of fettling be able to fit a single braided hose that’s what I would do.
    • #8503
      chris
      trying to find emulsion tube bolt for2008gv125 any ideas or does anybody have used carb for spares
    • #8512
      Post a new topic of your own and please include picture uploaded to your new post, as it helps a ton.
