    • #21039
      Biduchen
      Engine swapped to a nazablade 250 but my wiring system is still My hyosung’s
      Hello, I’ve gotten an engine swap for my hyosung gt250r but the engine is from Malaysia. Right now the problem is with my Ecu fuel injector system thing is fried, I’m looking on Lazada and aliexpress for an ecu.
      The ecu has two ports but my hyosung only has one port so I’m wondering if it’s do-able if I bought the ecu to put it into my wiring system I have going on right now.
      Any answer helps, Thanks a lot.
    • #21041
      Two  Ports ECU = Delphi  ECU.  This requires a harness with 2-plugs for the Delphi ECU
      Delphi Electronics have also changed, so to be safe get parts for 2014+ onwards
      2008 – 2012 = Daewoo & Sentec ECU = Not made anymore and very very very difficult to find and fix!
      So i would advise to upgrade all electrics to 2014+ model including harness , and you will find these parts on EBAY USA  (It’s a big 250cc market)
