Viewing 4 reply threads
    • #3884
      Gareth
      Cannot source intake manifolds anywhere…
      Well one place at 135 an intake rubber, no thanks
      Any help appreciated
    • #3887
      I had loads but sold out this week, will need a month to try buy more in bulk, the breakers charge me 60 per piece
      MotoGBHyosung trade in the UK wants 98 a piece i can’t justify myself paying loads in bulk either!
      I may still have a rear 125 probably still in drawer if it isn’t sold already,  you may end up having to email if still needing it
      Gotta have them while you can as EFI will world will take over soon and the production of these things will stop, its a shame only KRMotors makes these strangely shaped things! lol.  I digress.
      Also check the UK owners club on facebook as there is 1 or 2 lads breaking their bikes, you may ask them if they still have the engine manifolds for cheaper probably.
      Germany, and much of EU, UK are places where 125s are common place but their stores ? That’s another story! –  US is all 250 and 650 commonly which is no suprise so not much of a dedicated trade network over there to supply 125 intake boots.
      If push comes to shove, try me in a month, i may convert to 250 intake system inc correct air box as the rubbers are in different shapes and styles! – I usually do this on customer bikes dropped off to me.
    • #3925
      Krzysztof
      Hello, I am also searching for intake manifolds. You mentioned about swap to 250 intake system, how complicated is this procedure? I need only airbox and intake boots from 250 to fit everything correctly?
    • #3929
      You may email me as I will have the front and rear collected today again from a stripped bike, as i’ve been asked by others to get some. So will likely have it when i dig around.
      As for 250cc:
      – correct shape manifolds (there is variants)
      – 250 intake o-rings (125 ones won’t fit under them)
      – 250 GT airbox yes.
    • #3942
      Krzysztof
      Thank you for your quick answer, right now I prefer to modify intake system to use new 250 manifolds instead of used 125s.
      When it comes to the manifolds I wonder if ones with code numbers 13120HM8101 and 13110HM8102 will fit for this modification?
      Is airbox with 13700HM8101 number suitable for this swap? I found that it should fit GT125 / GT125R / GT250 / GT250R so there are also some kind of variants of this part?
