Viewing 2 reply threads
    • #7910
      Nick
      hi can any one help me my bike is up jetted to 92.5 lextech exhaust k&n filter starts runs ticks over and pulls of fine I can get any thing over 62 ish with these mods I thought I was going to get a treasure 70 plus
      I have had the bike in peices so many times getting things I can not change the speed what so ever is there to much fuel isit the coil can yous help me plz
    • #7918
      Firstly, welcome sir 🙂
      This may go over your head but please trust me,  can you do the following below  first
      • Let it get hot for 10mins.  Then do a compression test.
        Tell us what PSI each cylinder is , on full throttle. both plugs out.
      • Can you allow the bike to get overnight ice cold (required) then wake up , do a clearance check with a feeler gauge by taking valve covers off.
        Tell us what each valve says,
        eg.  Exhaust Rear (sprocket side) = 0.26mm
        eg.  Exhaust Rear (cam chain side) = o.28mm
        eg.  Intake Rear (each side) = 0.13mm
        Repeat
        This
        For the front engine.
        I will upload more manuals on the site when i get time.   In meantime, checkout manuals lib site for “GT125 Service Manual” and follow instructions on how to test compression or clearance or let a garage do it real quick and get proof on paper. Don’t trust their lips.
      • Also,
        While at it, check your clutch plates with a VENIER CALIPER and measure thickness of each plate.
        Also check how long the spring is  (standing) , don’t compress a clutch spring.   Eg. springs x2 35mm and other springs 32mm long etc..
      What i said above, is critical to hit the 80 mark,  otherwise the bike won’t do it no matter how tuned it is. So to save you money buying random things. Lets make sure the engine itself is healthy with the above checked.
      Please report back and let us know how you get on!
    • #7919
      Nick
      Thank you very much Marcel i appreciate that i know that my clutch is worn ive had to out and its warn and also judders will this affect my top speed tho i will do these checks weekend all of them and get back to you thankyou
