Viewing 2 reply threads
    • #734
      Njago
      I need some help my gt is missing the top of the air box last owner put a flat bit of plastic on the top drilled holes In it 😥 no air filter at all In side !  I have bought a air filter silly question were is the best place have the air intake as was going make a new top
    • #735
      Can you attach picture and show us the current state ?
      Worse case scenario is that you may need to replace the airbox if the top half is missing.
      I have no idea if its possible a top half can be ordered & resealed. But i’ll  check.
    • #738
      Dale Boniface
      Hello pal.
      Without pictures it hard to tell what exactly you mean. I’ve done a quick search on eBay and a whole new airbox unit ( which you will probably need ) your looking at like £50+ :(.So the fact you actually still have the structure base and sides is good enough for now….
      📝If I was you I’ll stick and are filter in there.make up a new lid to surround the top of the box. Basically re copy the design of airfilter box.
      📝If you have a pair of your mum’s/misses tights Laying about steal them!!! Cut them to size you need, put a TINY drop of oil on them(so it’s evenly spread) them attach over the top of the airbox to act as a temporary filter. MAKE SURE THEY ARE FIRMLY ATTACHED.
