- This topic has 12 replies, 5 voices, and was last updated 5 years ago by â™ ï¸ M77.
Mar 28, 2020 at 3:11 AM #4024
Hey all, this is my first post.
Got myself a new Aquila GV125S recently. Currently loving it. Only issue is I’m finding the mirrors very difficult to see with. Keep having to tuck in my elbows. Does anyone have any suggestions for replacements?
I did think bar ends would be better, but didn’t want to cut up grips before finding some that would definitely fit. Thanks!
Mar 29, 2020 at 1:47 PM #4034
Hey 👋
Welcome to the site , and nice purchase , you may be one of the very few (if any) that have got the efi 125 hyosungs.  If you do some kind of topic-journal on this forum, i will follow it , i might get one who knows! Got the older design GV250 efi myselfspeaking of design, the mirrors you mentioned can have their stalk extended. A local bike shop near you should have some kind of “mirror stem riser extension” (I am not sure about ebay as i rarely quote chinese sellers lol, but check out AmazonUK though!)
It has a male and female ends, so you put your normal mirrors on it and the stem extension goes back inside the handlebars, this way the mirrors are lifted up (height wise). You would need to confirm thread size on your current mirrors (I couldn’t confirm off my head right now)
As for bar ends, I don’t really bother with them personally because they vibrate to the point you can’t see clearly and i’m always filtering the traffic , so i’d rather they didn’t get knocked off lol.   To be fair most are cheaply made for that reason.
You could checkout J&S Accessories website for mirrors , i did get some from that shop (the normal tall aftermarket ones, they did me fine on the GT125 comet, it wasnt some kind of knock-off that would give problems later). They were 10 mins away from me , though i have no idea about their store locations near you but do do online orders im sure.
Waiting for the GV125S to get enough riders, then i should do few ‘plug-n-play’ accessories for it. I really want to… {using my own test bed even!}
Mar 29, 2020 at 5:48 PM #4039
Hey Marcel, thanks for the recommendation. I’ll have a look into stalk extensions and will let you know how it goes. Unfortunately not managed to get out much due to the current lockdown. Hopefully it doesn’t last for too long now that the weather has finally improved 🙈
Apr 24, 2020 at 2:53 PM #4310
So after much waiting for stock and delivery, finally got hold of some mirror extensions that fit. Main issue is both left and right mirror threads are in reverse so getting two reverse thread extensions in the correct size was a bit of a struggle. But got them and they’re now fitted.
Appears to much improve visibility as can easily see past my elbow now. Hopefully will get out on an actual ride soon, with all this lockdown malarky going on ☹ï¸
Apr 25, 2020 at 12:07 AM #4330
Looks good fella! – Being able to see the odd twat behind you is always ideal before any evasive action lol.  Well done!
I’ve started to slowly put small bits up for this bike, one of the big exclusive bits i’m eager to do is the 520 chain conversion kit that everyone raves about on the carby bikes . I may possibly PM you or someone else i know with the EFi GV to be a guinea pig to test the kit. I’ve seen that stock does 75 (just like the old GV125 carby, but i get texts now of 87 ish at best on the 520s but max chain does is 94) . If i can make the EFI GV125 push beyond 85 without loosing the crucial acceleration , then we have won lol.   If i think of something else to do also , i’ll probs make sure this site does it lol.  Who knows, my brain doesn’t stop haha.
May 15, 2020 at 10:59 AM #4424
Morning
I have purchased the mirror extenders from J&S.
Bike it Mirror Extender 10mm Yamaha
However, i have discovered that it came with a reverse thread bolt into the motorcycle.
Am i right in thinking that the bolt to the bike should be a normal thread? if so its just an M10 bolt?
i got it yesterday and could not work out which bolt is reversed?
any help on this would be great. 😀
May 15, 2020 at 5:35 PM #4426
On my bike both left and right mirrors were reverse thread. I ended up having to order two reverse thread bolts and extenders off eBay.
May 15, 2020 at 7:04 PM #4427
Ok so the ones I bought do not work.
wobbles on the bolt holding the extender to the bikeany chance you can link the ones you purchased as I’m now not sure which ones to buy?
any help would be ideal.
Jan 11, 2021 at 7:00 PM #4435
For some reason my phone won’t let me share the link so have screenshotted the item and the seller. Should find it with a quick search, mate. ðŸï¸ðŸï¸
Sep 27, 2020 at 10:27 PM #4907
Joe, could you copy in a link to the risers you got please. I have been having real trouble trying to get some from shops and online as they either don’t fit or threads aren’t correct.
Many thanks
Jase
Sep 28, 2020 at 7:37 AM #4908
Sorry folks, I thought I’d posted this ages ago, but I must have totally forgotten.
You’ll need to buy two obviously as both sides are reverse thread.
Jan 23, 2021 at 12:13 AM #5409
In regard to bar ends, on the Hyosung’s are they one piece or are you able to take the end off to replace with an aftermarket one? Or likewise do I have to replace the whole clip on?
Jan 23, 2021 at 10:46 AM #5410
If you have the naked GT it should have a straight bar with factory bar ends already.
The GT650S and 650R have solid clip ons yes. they are still the most bolt on clipons due to the fact top fork clamp holds them extra secure by 1 additional bolt. Look under neath one you may see what i was saying.
Aftermarkets tend to be chinese made universals not something i would dare fit myself. yes other brands may fit the fork size , how to stop them rotating (forbid) is another question. Even though they are tight on fork without additional bolt assissted by top fork clamp, i still have better confidence from oem ones.
There may be a way to do it to original fork clamped clipons but time & effort?
