Viewing 3 reply threads
    • #20618
      Bluey142
      I am hoping someone can suggest where I should set the two adjusting screws (air and fuel) on the carb as a starting point.
    • #20628
      Mix screws generally on that bike start 1 full turn from seated or 1.5 and see how it behaves?
    • #20629
      Bluey142
      Thanks,
      On my first go, I think the float stuck as it wouldn’t go then gas came out the overflow. Tore it down again then used your suggestion and with some tweeking I have it running reasonably well. I’m letting it sit and will see how it behaves tomorrow.
    • #20630
      Thanks,
      It’s not a bad idea to go through everything once more , good job!
