    • #20988
      John4242
      I need help. I need the dimensions of the timing strips on the magnito wheel as mine are grinded off
    • #20990
      There is no public info on that request but where it got sheered off , measure the where it would normally be, Hyosung used different size strips on the magneto rotor but there will be a mark showing you where it was and how long /wide it is. Thickness estimated to be about as thick as a credit card (just off my head!) i have no personally measured it.
      Get an EFi flywheel rotor for the Hyosung 250 and use that to measure the thickness , it will be similar to the old one. Obviously don’t use the flywheel as it’s for EFi model models.
      Hope that helps!
