    • #19119
      Morph
      I have a hyosung gv650 2006 carburetor model I bought it as a none runner it has been sat doing nothing for a number of years
      Restored the bike it started and ran but the exhaust was alot of oil due to the bike being on its side when the bike was running alot of smoke due to this so took all baffles/silencer out also disconnected side stand switch
      At this point the bike still started but alot of back firing checked timing was OK checked plugs coils ect spark plug low/weak spark so decided to change the following parts
      2 coils, stator, rectifier/regulator, plugs, solanoid also picked up a front safety bar
      Changed all parts but now it won’t start checked plugs and no part until key is turned off then it sparks
      The front safety bar needed modification done that and welded it on but forgot to disconnect battery but the bike was already not running and with no spark on plug until I switch off
      It’s as if its on a delayed reaction
      Any ideas what the issue can be
    • #19132
      This topic is kind of a duplicate, so it is locked.
      You have been responded to below:
      Starting problem – Hyosung gv650 2006
  • The topic ‘Low/weak spark first now no spark – Hyosung gv650 2006’ is closed to new replies.
