Viewing 2 reply threads
    • #7045
      Kernow
      I keep seeing info for earlier GV125 with 6 gears. My 2011 has 5 gears and 6 sounds very interesting.
      Hyosung manual says 6 gears and tech info sites have early GVs with 6 gears.
      Is this the case did they have 6 gears at any time?
      If they did how did it change top speed etc?
      Can newer models be altered from 5 gears to 6?
    • #7073
      They did exist but much rarer though! –  It is now common they are now 5 speed,  as is the GT125 bikes.
      It is the GT650 and GV650 still to this day share the same engine but  the GT650 has 6 gears.  (Sometimes the GV does!) – Also depends on the markets Korea sells the bikes to.
      Don’t worry though, the 5 speed gearbox on the 125 is more than adequate for it as the 6th would be like some kind of overdrive gear.
    • #7082
      Kernow
      Thank you for that info Marcel, it has shed light on that.  I have no intention of altering mine but info is useful. I will keep my eyes peeled for an old 6 speed 125 as it has peeked my interest.
      The fact that the 650 shares the same bottom end is interesting also, shows the strength of the 125 set up.
