- This topic has 16 replies, 3 voices, and was last updated 6 months ago by
Luke R..
Oct 22, 2024 at 11:28 AM #15262
BrianParticipantDo the upgraded jets give better acceleration and top speed? Thank you
Oct 22, 2024 at 4:11 PM #15266
♠️ M77KeymasterThis mod is free and does wonders on the bike!
Pilots = Size 15 is a good downsize , simply because the factory 17.5 is a bit too big
Mains = Depends what exhaust you have (upload a picture please)
Regards
Oct 22, 2024 at 6:46 PM #15270
BrianParticipant
Oct 22, 2024 at 6:47 PM #15271
BrianParticipantI have no idea what tyoe if exhaust this is
Oct 22, 2024 at 6:51 PM #15272
BrianParticipantThe guy who I bought the bike from was running 122 main jets, it was carbon fouling alot.
Oct 22, 2024 at 7:30 PM #15273
♠️ M77Keymaster90 & 92.5 is the absolute max and probably the best way.
The bike pulls better with the baffle (find a way to make the “HOLE” of the baffle about the size of a 10p coin)
Oct 22, 2024 at 7:40 PM #15274
BrianParticipantThe baffle on this bike is about 2 inches marcel.
Oct 22, 2024 at 7:42 PM #15275
BrianParticipantIm running the 90/92.5 atm and she runs pretty good, need some fine tuning as still slightly rich
Oct 22, 2024 at 7:51 PM #15276
♠️ M77Keymaster2 inches = Hole Size (where exhaust fumes come out of ?) or just the side ways length of it ? I was on about the hole size.
Oct 22, 2024 at 7:56 PM #15277
BrianParticipantYes the hole at the end of it lol wasnt me bro
Oct 22, 2024 at 7:57 PM #15278
BrianParticipant2 inch hole size Marcel
Oct 22, 2024 at 8:01 PM #15280
BrianParticipant
Oct 23, 2024 at 6:57 PM #15309
♠️ M77KeymasterIt looks so dark in there, i can’t tell if the baffle is even there , it looks like its baffle-less. ? I could be wrong , take a picture of that hole with camera flash ?
Sorry i delayed.
Oct 23, 2024 at 8:14 PM #15315
BrianParticipantThere is no baffle
Oct 24, 2024 at 10:56 AM #15320
♠️ M77KeymasterThere it is, you found another source of power loss , no baffle means the bike will lose too much torque at the lower revs , it has to scream more to get going
I gurantee you. a baffle inside a 125cc will make more power than without , and you can even test this yourself , the vtwins make peak power around 7k-10k rpm (pointless revving past 11k rpm as that’s a sure way to cook the engine)
Measure the hole , and find any baffle that will fit in there, make sure the baffle can be modified so that “gas fumes” exit the bike at a 10p coin size hole (get creative) (10p coin is 24 mm (0.25 cm approx) yes that small , and it will still hit 70+ if tuned right.
Factory GT125R has an oem exhaust with a lot of restrictions but still managed to do 82mph indicated (ish) , this is factory. So ignore anyone that advises running without baffle is better (unless they want hearing aids faster lol) , it is still loud baffled on aftermarket cans.
Lextek OP1 and Black Widow FULL Size cans are my recommendations and what i use on all bikes, since they are also road legal & pass MOT with no issues on noises. Others are HAWK Hyosung Exhausts , 2 Brothers USA (may need baffle!) , MTC UK (baffle it hard) , Scorpion Hyosung Exhaust.
The 1st two i mentioned are just my persona pics. Hell a full size micron isn’t too bad! – any can is OK as long as it doesn’t fail your MOT & isn’t a “shortie – midget! ” , hyosungs hate midget cans . Even more so on a GV125 Cruiser (it literally looses like 70% of its power if it senses midget cans added to it) , i had to put the OEM one back for the customer and it’s been happier since.
Oct 24, 2024 at 6:30 PM #15334
BrianParticipantThis is inside Marcel. Previous owner may have removed baffle?
Oct 24, 2024 at 6:44 PM #15336
♠️ M77KeymasterBaffle is missing 👍
May 18, 2026 at 9:33 PM #22597
Luke R.ParticipantCan Anyone Recommend a Jet Upgrade for Gv125 2016 please
