Viewing 2 reply threads
    • #10088
      Harvey
      Hi all
      GV125C Aprila indicator upgrade and cheap universal windscreen
      Being cautious of what I spend, as aiming to get my mod 1/2 pass late summer and upgrade, but in the meantime I felt the standard indicator bulbs were a bit dull and wanted to reduce the wind factor a little.
      I bought some LED bulbs from Amazon, which have worked perfectly, links below to daylight and night videos.
      The screen came from eBay for an amazing £31.50, so didn’t think I could go wrong. It’s perfect for what I need, but others may want larger. Can be seen in the video.
      Hope this is useful for some of you.
      Daytime
      https://1drv.ms/v/s!AiY7mErm8mwPxm76eqULfIJ2LmNi
      Night time
      https://1drv.ms/v/s!AiY7mErm8mwPxm26D-Kx1E5cS49y
    • #10100
      Nice LED bulbs , are they actually 20W each or 20W total for all 4 ?  I say this because the OEM relay usually wants a max of 10w per bulb and the harness itself.
      • #10105
        Harvey
        Good question, I’ll check and let you know.
        They work perfectly okay, the timing seems okay as you can see in the video.
        20w for an led bulb is quite high, so they may be 4w each.
      • #10111
        Harvey
        Based on everything I’ve read they are 10w per bulb.
    • #10116
      The ad says 20w , i assumed every bulb ,  then its 80watts if all light up at once! – Could cook the harness since if you notice your highbeam lights draw 55w, and their wires are thicker than the indicator wires  ( watts vs current (amps) vs ohms, if you want to get technical calculating it yourself)  = The harness has a 15A rating.
      Hopefully the seller said its actually 5w per bulb 🙂   ,  after a ride just check the buzzer winker relay isn’t hot or anything.
