- This topic has 9 replies, 3 voices, and was last updated 3 years, 9 months ago by
Steffan rees.
Nov 23, 2021 at 1:46 PM #6645
PeterParticipantCan anyone please tell me what the factory air/fuel mixture screw settings are as mine have been messed with they’re currently at 3 turns at the front and 4 at the rear
Nov 23, 2021 at 7:27 PM #6646
♠️ M77KeymasterKorea did not reveal the turns to discourage owners tampering with them , and due to the fact 125cc and 250cc , GV and GT, have slightly different turns from each other based on what model the bike is and the jettings used.
So your profile says GT125R (a carb with a jet pump attached to the rear float bowl), use around 2 and 1 quarter to 3 full turns max. Rear being slightly richer as it’s the hottest cylinder.
1/8 of a turn does make a difference, so i would encourage a carb ultrasonic cleaner and dead-on adjusted clearances & lastly a religously clean intake system that’s also leak-free including how far the airbox swallows the carb, and intake manifold orings changed.
You will find that if any of the above ^ is not done, the mixture messing will be a nightmare to get it spot on.
Sometimes tools to anaylize the heat of the exhaust pipes also helps , even as much as reading the air/fuel ratio that’s coming out of the tail pipe. Clean & new spark plugs will be a good hint after a short run.
Show us the plugs when done. (though , it can be expected to go through 1 or 2 plugs , as per typical “plug chopping” process)
I hope this reply helped.
Nov 23, 2021 at 8:45 PM #6647
PeterParticipantThank you your a star I’ll give it a go tomorrow also the gt125r has 5 gears not 6 is this right?
Nov 23, 2021 at 10:51 PM #6648
♠️ M77KeymasterThank you your a star I’ll give it a go tomorrow also the gt125r has 5 gears not 6 is this right?
Correct even 250’s have 5 gears , they don’t need 6 gears for what they are to be fair. Although 6th be a little nice overdrive haha.
It took 6th gear for a Yammy YZFR125 to hit the 80s , hyo does that in 5th.
Feb 14, 2023 at 5:18 PM #9640
Steffan reesParticipantWhere are the fuel and air mixture screws on the carbs a comet 2010 125 please ??
Feb 14, 2023 at 6:59 PM #9642
Steffan reesParticipantOkay thanks I found them I’ll give them a go because it’s still running funny after I clean the carbs out
Feb 14, 2023 at 7:01 PM #9643
Steffan reesParticipantWhat’s the right mixture for the front and back carbs please for comet 125 just wanna make sure it’s right
Feb 14, 2023 at 7:28 PM #9644
PeterParticipantThere’s no right answer to that it seems to be unique to your bike but most will happily run on 3 turns on either
Feb 14, 2023 at 8:36 PM #9648
Steffan reesParticipantOkay thanks I’ll will figure it out tomz thank u for all your help
