- This topic has 7 replies, 5 voices, and was last updated 5 years, 1 month ago by
♠️ M77.
Sep 6, 2021 at 5:53 AM #6224
Stuart HollandParticipantI have noticed a tapping noise from crankshaft anyone else had same problem please
Sep 6, 2021 at 8:59 PM #6226
♠️ M77KeymasterDo you have a youtube account or instagram or tiktok that you can upload a video and share the link here , so we can have a listen.
Or you can try to describe the noise precisely where in the bottom end you hear it ? If it does that cold or not ? or while neutral or riding (under load)
Any history of the engine being opened up for overhaul if its old ?
Sep 8, 2021 at 3:52 PM #6231
Moustache ManParticipantYep, similar issue with me. Its something to do with the clutch, been riding like that for years and nothing terrible has happened.
It only occurs at low revs/idle, in neutral when the clutch is disengaged. The second you pull in the clutch, the noise goes away.
I was told by a garage that it was just regular clutch rattle/noise, and it has not been a problem since (with failing MOTs/servicing). It hasn’t affected performance either.
Sep 26, 2021 at 9:19 AM #6315
CarterParticipantYep, similar issue with me. Its something to do with the clutch, been riding like that for years and nothing terrible has happened. It only occurs at low revs/idle, in neutral when the clutch is disengaged. The second you pull in the clutch, the noise goes away. I was told by a garage that it was just regular clutch rattle/noise, and it has not been a problem since (with failing MOTs/servicing). It hasn’t affected performance either.
this is a different noise and a different problem and is caused by either the clutch release bearing or faulty or unevenly tentioned clutch springs
Sep 18, 2021 at 2:18 PM #6298
Stuart HollandParticipantOk thanks
Sep 26, 2021 at 9:13 AM #6314
CarterParticipantThis is a common problem in these engines I have have it a couple times it’s the condrod bearing has failed unfortunately it’s a one piece crankshaft so you would have to replace the whole crankshaft £220 or you could pick up a used bottom end for less than half the price lol however often if the noise gets quite loud the the extra play in the bearing could allow the piston to come down too far am may shatter crack at break the fin off the piston
Sep 29, 2021 at 5:25 PM #6342
DAVIDParticipant
Hi Guys, is this on the new 2021 bikes, I hope to god it’s not, as its getting sent straight back to Korea -
Oct 4, 2021 at 1:29 AM #6384
♠️ M77Keymaster
Hi Guys, is this on the new 2021 bikes, I hope to god it’s not, as its getting sent straight back to Korea2 or 5 Year warranty (dependent on Sinnis UK and your dealer & if Hyosung still wants to Honor 5yrs , but i think so.) , and i wouldn’t worry too much as the injected engine is entirely different , so any issues your dealer will sort it for you under warranty , just take care of her and she will keep going.
