Viewing 4 reply threads
    • #22884
      Hamder
      Hi Forum after a really hot day where i drove about 40 km at speeds between 80-150 km/h, when i reached home and stopped at a red light, i saw the heat indicator rising really fast to the point where it was overheating. The cooling fan didnt switch on and the FI lamp then turned on. i havent driven the bike since but ive tried to see if i could sort the problem out,
      When i turn on the bike the lamp turns on after around 5-10 sec. and if i try to rev the bike it turns off in an instant. i havent been able to find which connector i should short to get it into dealer mode and get the fault code reading so im pretty stumbed at the moment.
      I got the bike really cheap and its been running okay for an older used bike, but after this heatwave it couldnt handle it.
      i hope to get some help from you lovely people. Cheers.
    • #22892
      Turn the key On/Off   3x or 5x   OR     Turn Key on –> Then press kill switch 3-5x times quickly and wait for the red Fi light to flash.
      Count the sequences and let us know ?
      Eg. 5 blinks , pause, 4 blinks , pause , 6 blinks   = Bike said Error is 5-4-6 , it will repeat itself.  Or it will pause for longer , then send out another error code  (if 2 devices are at fault or need attention)
    • #22901
      Hamder
      I got the fault code c24 so I checked the front ignition coil and it wasn’t connected, I connected it and it fixed the problem!
      my next problem is that its not charging the battery when I’m riding… any pointers to what the problem may be?
    • #22906
      Rectifier issues or the stator is wanning.   Get a pocket meter and test your stator according to the service manual instructions.   Stator first, check,  then check RR
      Sometimes a new RR (Reg Reg) gets cooked by a failing old stator, also open the casing to make sure the windings didn’t get burnt out  drain oil first
    • #22913
      Hamder
      Found the cables from the rectifier, two of them were damaged. I fixed the problem and got 0 issues now 😁
