Hi all, new here but I was on the FB group a few years ago.
I’ve got a 2011 GT125R which has developed an issue: it is not getting fuel and idles high when it eventually runs (normally off carb cleaner) – I’m guessing it’s my front manifold, this felt loose and had a lot of play. You can lift it and see a gap between the inlet and the engine, presumably this is upsetting the Vacuum fuel system and creating an air leak.
I managed to get the bolts off (with a lot of WD40, heat and force). I’m going to try and fix it using washers and perhaps some glue/sealant if anyone can recommend any?
I bought a new one off ebay, however it’s shorter than mine and does not fit on the carb as a result… Could anyone help me identify why that is? It says GV125 F on it – is it off a newer model, or the Aquila perhaps? Photo attached. It will also be for sale of interested – £55 – which is what I paid.
