    • #5813
      Jordan
      Hi im new to the forum I’ve recently bought the hyosung comet 125 pictured as a project it run but idled really high with choke and then cut out so had carb strip and clean then would not run when all built back up so traced back to the fuel pump and realised it was vacuum fed from the inlet rubbers so took pipe of and run fuel straight from tank then it run but would not rev cause the vacuum to fuel pump must be something to do with it so i checked inlet rubbers and the front one was bogged together in pic and had sealant put all round bolt holes took off and its knackered i think this is the issue is anyone selling a comet 125 front inlet rubber i cant find one anywhere also im after a rear caliper if anyone has one.
    • #5815
      There is ways to repair the inlet rubber when people used things like tiger seals and what not ,  to be honest personally ill only have inlets to sell in about a month or more ,  due house move i am not working as full time as i would like until i settle in a new time and rebuild my workshop in a new area.
      Though, I do have caliper bodies ready for dispatch on the @evocrest ebay channel
      Also stainless steel piston kits ready to go in the hyoriders shop above ^ , as I usually keep emegency sets for urgent orders than waiting 2 weeks for my cnc guy to make some.
      Also likely to have some used but good nick OEM pistons  (x2) , sending me an email would be best or a PM on this forum for further info.
      If your pistons aint rusted badly and pistons move freely, it could be the master cylinder itself and (50/50) chance brake fluid is old.
