Viewing 3 reply threads
    • #19652
      PaulGT250r
      I have a 2009 GT250r EFI and need help with images on where the vacuum hoses connect to, where the vacuum valve mounts and fuel connection from the tank to the throttle bodies.
      The breather lines out of each cylinder, where do the connect to?
      Thanks
      Paul
    • #19654
      Simon
      As you sit on the bike the under the tank on the left hand side is the emission valve the pipes from the cylinder’s connect to that, don’t bother getting some blanking plates for the cylinders, block off the pipe that goes from the valve to the air box but leave the valve plugged into the loom.
    • #19656
      PaulGT250r
      Thanks Simon for the info.
      On the air box there is a sensor with a 4 pin connector that has 2 pipes coming out of it, what connects to it?
      Any photos would be helpful.
      Thanks
      Paul
    • #19657
      Simon
      That is the idle control solenoid, two pipes one from each manifold connect to it
