Viewing 2 reply threads
    • #12938
      Marcus
      Hello All,
      My headlight and backlight have suddenly stopped working on my GV650 Aquila.
      Any ideas please.
      Cheers
    • #12943
      Can you check your relays ?   Sounds like relays have gone burst  (it will have various if it is an EFi 650 Injected model)  , Carb Models have less relays.  You didn’t order a new one already did you ?
      Then if the lights went burst, check the bulbs themselves ?
      Also , check the wiring harness if there is a kink , break,  or water invasion?  or shorting to the frame?
    • #12969
      Marcus
      Thanks for the info,
      I’m waiting for the relay to be delivered. Changed the bulb, so it’s not that and can’t see any wiring issues. So I’ll change the relay and let you know how it goes 👍
