    • #22701
      Hamder
      My issue is with the handling of my bike. When I drive around 30-50 km/h it feels like the bike is fighting and wants to either steer to the right or left. I can’t let go of the handlebars and keep the bike straight. When I lean right in corners the bike feel extremely heavy. Front tire is at 2.25 bar and back tire at 2.5 bar pressure. Help the wheels and forks seems to be aligned and it bothers me that the steering is so heavy and not smooth.
    • #22702
      Try to loosen the steering nut   (it says in service manual if steering is too heavy,, check steering yoke top nut  or  check the bearings   or  possibly the two “castle-nuts” which lock the bearings and yoke bar inside ,  loosen a little bit so the bearings are not too squashed down too hard.
      It’s tricky to explain but i hope i made some sense ?
