It sounds like a battery went out (inside the dash) – Some hyosungs have it (so look inside and check) but other Hyosungs even GVs store that in the micro-chips. I’ve been there myself.
I just tell the MOT guy to check the last mileage and i took the picture when it turned zero , then told him how many miles i did afterwards
You can also check the “Trip Meter” to see if it saved anything by pressing the select button, but if both say zero , then yes you encountered the rare moment where the dash just went to zero!
Unless you have a spare harness to connect the dash and battery away from the bike + front wheel on a conveyor belt + run it for days , the dash will start recording mileage because it thinks you’re driving. I’ve haven’t found other ways to cheat the mileage counter without breaking something.
