Viewing 4 reply threads
    • #21336
      Logan
      I wan to to make my full power gv650 efi a lams while I’m on my p plats. Can I just swap my ecu dose it need to be a gv650 ecu or can it be a gt650. Also is there a way to get a tacometer on my gv650
    • #21341
      ā™ ļø M77
      While i am not in AU , so i am not too familar how they restrict it down there.Ā  Here in the UK,Ā  they just restrict the throttle bodies so that you can’t do a full throttle twist , usually there is a stopper welded that limits how much the intake opens up.Ā  You may have to look at yours to see if that was similar.
      GV650 ECU for GV650 only. As GT bikes have their own harness that matches the ECU it comes with and may have 1 or 2 extra sensors more than the GV.
      As yours is a DAEWOO or (rarely a Mitsubishi) ECU ,Ā  you’re locked down to that specific ECU to ensure compatibility (not expecting issues putting a wrong a ECU) –Ā  ThoughĀ  some people have tried to shoehorn a GT ECU in to a GV,Ā  it was hit / miss .Ā  Ā  Ā  Ā GT650 would also have LAMS done in your country if that was the case too,Ā  Ā which leaves us to look at the throttle bodies for restrictions applied.
      Tacho = You can study the wiring diagrams uploaded on this site via its service manuals , look for a wire that says TACHO Signal,Ā  then get another “standalone” RPM reader , mount it to the handlebar if possible as an additional gauge.Ā  Tap in to that aformentioned wire.Ā  That’s how I would try to do it personally.
      • #21345
        Logan
        thank you. do you know where i can find a restiction plate
    • #21346
      ā™ ļø M77
      You will have to take apart your air box , then look around your throttle area for the restrictions that may be placed.
      • #21347
        Logan
        Where can I buy one
    • #21348
      ā™ ļø M77
      Where can I buy one
      Look around your local garages for SV650 tunners , they will fabricate or get SV parts to retrofit to your GV and get it certified if your insurance requires it. SV650 and GV650 are different but distant cousins , so it wouldn’t be too much work (hopefully) for your local garage to do it & put it on a dyno to see how much torque its making & HP. Here in UK there limit is about 46 HP for restrictions to qualify, you may have to check your local laws.
      • #21357
        Logan
        ok thanks
    • #21947
      Danarae
      A bit late to the party here, but I bought a GV650 lams over in Perth, there is a post on here about de-restricting the throttle body, and how to do it, you don’t need to remove the airbox, only the left hand side intake, then you can see the throttle mount and the stopper. Mine had actually already been removed, but tbh if I were you I wouldn’t worry about it. I have my RE PDA on Monday and I’ll ride mine until it dies or I get my R licence and upgrade šŸ™‚
