- This topic has 9 replies, 7 voices, and was last updated 1 year ago by GarryTheGreat.
Jun 27, 2020 at 1:00 PM #4620
F1 is flashing when riding and red light stays on all the time how can I find out what the fault is there is no Hyosung dealer near to me. The bike starts and rides fine, any suggestions
chris
Jun 27, 2020 at 9:20 PM #4621
There is a socket on the bike somewhere you need a piece of wire to short the terminals now I believe it needs to be running as the hyo ecus don’t store codes, the code will display on the clock then Google it or post on here & I do have a vast array of stuff laying about & I might be able to tell you what it is, I reckon it would most likely be a o2 sensor but one thing worthing checking on the battery is there a smaller wire connected to the earth? Check this as I know if it breaks it will cause the f1 light to be on at least on the 250 it will & tbh there’s not a lot of difference between them.
Jun 28, 2020 at 7:33 AM #4622
The diagnostic plug is next to the battery. Its the 2 pin plug.
Bridge it with wire. Ignition on for 10 seconds. Then press and hold select on the dash for about 6 seconds or more. The code will flash either where the clock is or the red fi light will flash a number sequence in flashes.
The 2012 onwards delphi ecu bikes ” Do” store codes.
Jun 28, 2020 at 7:41 AM #4623
This site also has the service manuals, they have all the info you could ever need. Codes, how to get them, what they mean. Etc.
Jun 29, 2020 at 1:40 AM #4629
Thx for the response sorry been away so couldn’t reply earlier. will try with wire, what site tells you codes and what they mean
Jun 29, 2020 at 8:59 AM #4630
Tried that method half a dozen times no codes came up neither did F1 red light flash, only option book of matches and a gallon of fuel this dam bike has been nothing but trouble since the day i brought it and its only done 3200 milesΒ π₯
Jun 30, 2020 at 10:04 AM #4645
Did you download the service manual off the forum on here?
You will see instructions to switch to dealer mode.
Jul 7, 2020 at 9:39 AM #4664
Hi Chris,
Any luck with this?
With the run(red) switch on, turn the key on and off three times, then count the flashing sequence of the FI light.
Post it here when you have it,
You can also find this info in the service manual.
Cheers Chris.
Apr 5, 2021 at 11:59 PM #5680
Hi Chris, Any luck with this? With the run(red) switch on, turn the key on and off three times, then count the flashing sequence of the FI light. Post it here when you have it, You can also find this info in the service manual. Cheers Chris.
Hi, Iβm new to this forum. I have the same issue. I did as you suggested. The number sequence I got was 10-8-5 and then back to 10. How do I find out what this means?
Aug 17, 2025 at 5:55 AM #20508
Hi I’m new too however mine is the same flashing sequence when I flick the key 3 times
10-8-5 then back to 10
