- This topic has 6 replies, 2 voices, and was last updated 2 years, 11 months ago by
♠️ M77.
Nov 26, 2023 at 5:21 AM #11756
JohnParticipantI have just finished restoring a 2012 GV250 Delphi. The bike will turn over and crank strongly with a new 12v-12amp battery but it won’t start. When I hook jumper cables to my trucks 12v-90amp Amaron battery the bike fires immediately and will stay running after the cables have been detached.. also the rectifier is insanely hot, don’t know if that’s related. Has anyone had this issue or and advice on how to fix it?
Nov 26, 2023 at 4:26 PM #11766
♠️ M77KeymasterWas the truck running when you jumped the GV ?
This question is very key.
Nov 27, 2023 at 2:35 AM #11775
JohnParticipantYes it was.
So is this a volts issue? The alternator is sending 14v instead of the 12v the battery has?
Nov 27, 2023 at 11:44 AM #11776
♠️ M77KeymasterI have to be sorry to be a bearer of bad news but when you start a bike , with a “truck running” , it means you sent too much “amps” (not volts)
14V is good but its like sending 5 gorillas to lift the bike up instead of needing just one , so it gets crushed when squeezed out by all 5. In other words thje strength of the current was too much for the bike even though it started.
It would likely mean
- Fried up stator
- 100000% fried up regulator (as you said it was insanely hot) , its not normal at all.
- If its an EFi bike, you possibly may end up having to replace defective sensors all over the bike one by one that use energy, such as your coils , ISCV, Lambda Probe o2, etc.
This can explain why it may not start on its own as who knows if the previous owners have done the same thing , current that’s too much = heat and heat increases “resistance” . If a part “resists” too much, it won’t fully pass the require signals to start the bike and run it effeciently.
So, tear down the bike until it is on bare harness , smell the harness for burn marks and ECU = these are so important that trying to find a new D-ECU’s or Harnesses for a GV specifically is difficult as it is (Since Korea has now moved on to GV300S and GV250DR 2021).
Replace these right away to be safe;
- HT Caps
- Ignition Coils
- Spark Plugs (CR8E only!)
- Stator Unit that’s for DELPHi
- Regulator that’s for DELPHi
If in doubt send an email , ill find the parts for you but hey….. you’re lucky it didn’t go on fire. Years ago regulators were posted online by Hyo owners of them going on fire.
Again sorry for the bad news but it looks like we doing an electrical reset and you can’t trust half the old electronics anymore. Things like stators / regs / coils are usually not “user-fixable”
Nov 28, 2023 at 10:43 AM #11782
JohnParticipantWell, that’s not what I was hoping to hear.
I changed the rectifier before you had written me back. I also put the 12v-12amp battery on a trickle charger and today the bike started on its own and idled for about 15 minutes. I took it out for a ride close to home and after 5 minutes the bike died. I sat on the side of the road for about 10 minutes, constantly trying to restart the bike. After about 10 minutes and 20-30 attempts it fired back up and I went straight back to the garage.. I’m sure I fried a sensor somewhere causing it not to start. Guess I will tear it back down and start over. Thanks for the help and I will message you for parts soon.
Nov 29, 2023 at 7:03 AM #11786
JohnParticipantWill a 2010 GV250 efi work as a donor bike for my 2012 GV250 efi Delphi? I know they have a different ecu but the coils and sensors and stuff?
Nov 29, 2023 at 9:43 AM #11788
♠️ M77KeymasterWill a 2010 GV250 efi work as a donor bike for my 2012 GV250 efi Delphi? I know they have a different ecu but the coils and sensors and stuff?
Daewoo uses Sentec or very early Delphi sensors.
Also stators , flywheels , ecu and all harness is locked to daewoo even coils may have different Ohms ratings
Little sensors like lambda probe ; airbox ISCV ; ET should be OK.
