Viewing 3 reply threads
    • #15568
      Vab
      Title basically. Rode the bike for around 30 mins, came back home, opened garage, got back on bike and put into gear, bike then cuts out.
      Any advice is greatly appreciated.
    • #15569
      Vab
      Fixed. Side stand issue
    • #15572
      Hey glad you sorted that out,  be sure to remove it and apply “contact” cleaner on it and make sure the “plug” is out of sight so that the front tyre doesnt chuck so much water at it.
      Then use grease on the actual kickstand & it’s attached switch down there so that it doesn’t seize up since it moves all the time  (stand down, stand up, stand down, etc…)
    • #15573
      Vab
      Thanks, Marcel. Will do.
