- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by
♠️ M77.
Dec 27, 2020 at 8:23 PM #5247
NorbertParticipantHi everyone , I’m in a need of help with my 2007 Aquila and its performance.
It doesn’t want to go over 45/50mph on a straight road… which on dual carriageway is just disappointing.
It had been recently serviced as well as had couple things replaced , like a new manifold rubbers and nothing has changed… -
Dec 27, 2020 at 8:47 PM #5249
♠️ M77KeymasterWelcome to the site and happy holidays
It would be useful if we know these (makes troubleshooting whole lot easier) , if we skip these , i won’t know how to answer accurately. History helps.
- Total miles on dash?
- Has it had valve clearances done? (can’t be avoided)
- Has it had its carbs taken apart and blasted clean (via air compressor, fluids and even ultrasonic clean?)
- what modifications does it have?
Dec 27, 2020 at 8:51 PM #5250
NorbertParticipantNo idea on current mileage of the bike…
9.3k miles on the clock as of now, yet it had 13k back in 2010 according to MOT history.
someone has been messing with the clock.cabrs are in poor condition, pilot screws seized which needs replacement but can’t get a hold of any.
Dec 28, 2020 at 10:29 PM #5264
♠️ M77Keymaster- Has it had valve clearances done? (can’t be avoided)
How about the other 2 points above ?
In regards to the carb, I don’t know if you can but can you take out spark plugs and upload on this site ? (Add media button on the reply box)
We can see if its running rich and which cylinder front vs rear.I rarely encourage messing with the air mix screws for many reasons unless a pro is good with the carb especially multi cylinder carbs , one engine can run a little richer than the other etc to aid in cooling as is the case with hyosungs and maintain some harmony
So, do you think its possible to disassemble the carb and then give it a clean (air compressor as OEM books say, and some liquid cleaner or some guy to do an ultrasonic clean job, probs £40 for the job if the carb isn’t so bad.
Least with an open carb its not just about cleaning clogged holes, how about slides being too scratched? torn? slide springs too tired? slide needle has been wrongly set in the LEAN setting ? (hence why I’d like to see your plugs)
Be ready to change plugs either case. to new ones.
Coils , Caps, Regulators are 3 common things that wane on hyosungs but lets do fueling out of the way , as it’s hard to attack many things at the same time. Dealing with each part / section of the bike will narrow issues down 1 by 1 . Any form of boggings , poor running is always either “valves too tight/too loose” , “fueling from the tank the carb inc pump” vs “sparking power” (plugs, coils, caps these 3 are married) – Regulator can just as easily slow things down a bit, again , electrics after the fueling is out of the way.
