Viewing 3 reply threads
    • #13750
      Connor McDermott
      my Gv125 is only running on one cylinder, though ive changed my sparks the wiring around one of the connectors seems to be loose or misfiring.?
    • #13752
      Basically the 1x coil is dodgy and needs replacing or did we miss something ?
      The connectors for the coils  (SPADE SHAPE) can be squeezed a tiny bit more (carefully) so it has a firm grip on the coil terminals.
    • #13763
      Connor McDermott
      Thanks Marcel I’ll swap out the coil see if it helps, or it’s maybe needing a bit of contact cleaning or do you think the wires in the connector could be loose.?
      Kind regards
      Connor
    • #13773
      do you think the wires in the connector could be loose.? Kind regards Connor
      It does happen and contact cleaner works a treat
