Viewing 3 reply threads
    • #10427
      George1133
      g’day, has anyone sourced the internal fork bushes to suit the 41mm USD forks?
      my forks are 2010 & require both pairs of bushes.
      thanks in advance
    • #10461
      Bushes in some regions  (funny enough) can actually be refered as dust seals and oil seals , unless do you have a picture of the actual part and ill confirm what you are saying or what happened to your old ones ?
      Sorry i saw this late!
    • #10474
      George1133
      nup, oil seals & dust seals are easy to find & are listed, but Hyosung don’t show these
      attached is a Suzuki GSXR parts page & items #6 & #7 would be the items i’m after
      excessive bushing wear is causing seal to leak.
      a local suspension repairer says that he might be able to match them if i supply dimensions or samples.
    • #10479
      If 6 and 7 are required, i don’t think Hyosung sells them anymore or makes them even though it is KAYABA that’s involved,  i may have a suspicion your local guy will take your old forks and try to match up with other Kayaba parts used on other suzukis .    If i’ve known Hyosung all these years , here in UK  USD forks are pricy items! – So we try to fix them locally as much as we can.
