Viewing 7 reply threads
    • #14912
      wolf
      So my 09 gt250r the front sproccet nut and washer keeps falling off. any specific reason? i noticed that some other pictures ive seen the washer is bent over the nut. but what could cause the nut to keep falling off and leaving me stranded and wasting money๐Ÿ˜‚?
    • #14914
      madbikeruk
      Have you got a picture as it would help
      the washer is bent up to help stop the nut from spinning
      How are you putting the nut on and tightening it up hand or impact gun
      Is there any place for a split pin orย  you might be able to wire lock it in place
    • #14915
      wolf
      i will send a picture later today when i get home
      im doing it by hand its all i have right now and i dont think theres a place for a cotter pin i looked๐Ÿ˜“ how would i wire locc it? ive never heard of that
    • #14918
      madbikeruk
      Had to do it for race prep on my old bike
      Did you use a torque wrench? If you need to stop it moving easiest way put the chain on, put it in gear (engine switched off ๐Ÿ˜…) get a mate to press rear brake or hang something from the lever ๐Ÿค”
      • #14920
        wolf
        meant to dorectly reply but it didnt work. do i bend the washer myself ? like the lip over the side of the nut? theres no place for a cotter pin sadly which i dont get. also do you know what size soccet ill need for the nut on my bike?
    • #14919
      wolf
      so do i bend the washer myself? over the lip of the nut?
    • #14921
      Simon
      Yes tap one side of the washer onto a flat face of the nut
      • #14922
        wolf
        ok perfect. you happen to know the soccet size of the nut? i cant find the size anywhere
    • #14923
      madbikeruk
      What did you use to tighten it up with last time ?
      If you can’t find a socket you can use a monkey wrench but it could damage the nut
      • #14925
        wolf
        i did use a monkey wrench fuz even tho i have a billion soccets none fit that one๐Ÿ˜ค๐Ÿ˜‚
    • #14943
      Sprocket Nut socket size is 27mm , and i agree that you need the rear brake pressed down hard with chain fitted to bike.ย  ย Keep in neutral as not to damage gearbox
      Torque for is 60-80nm for nut.
      Use “PERMANENT/SEMI-PERMANENT” loctite on the thread , that can handle high heat , make sure the shaft thread is clean!
      Also make sure shaft does not have damaged thread, because if a nut flies off, the sprocket will grind on the shaft thread , which could be an timely job to split engine and replace shaft again.
      Folding washer to nut = I fold twice , and I make sure the washer lips are hugging the nut tight and flat… I do this for every customer bike.
