Viewing 3 reply threads
    • #13237
      Reiss
      Doing a fuel tank switch over as I’m converting carb -> efi, so I’ve got the efi tank and I wanted to exchange my lock over.
      Unfortunately, there was no key provided with the EFI tank, so resorted to using a hammer & a flat head to break the old lock and got it open.
      Problem is now, I’ve got this internal plate and when I pull it into position and lightly hammer it flush with the edge of the tank, put my lockset on & then attempt to close/lock it, everything falls through and returns me to square one.
      Any ideas?
    • #13243
      I have never ever seen that before! , it looks like the tank will need repair / welding job as there should be no gap like that as if the small red center has broken away from the main tank upper shell.
    • #13398
      Reiss
      Solved: used chemical metal/epoxy to secure the inner plate to the tank! Apply your product, let it cure for 24 hours.
      Seems to have done the trick until I can source/afford a new tank
      Just in case anyone else runs into this issue.
    • #13407
      Thanks for sharing this! = But keep an eye though!  – Don’t loose the carby tank either.  very rare things.
