Viewing 4 reply threads
    • #5071
      Matt
      Hi, can anyone help. Went to work this morning and my bike has decided it wants to just not go anywhere above 8k revs and then make loud pops from the exhaust. If I change up a gear it stops doing it but then when hits 8k revs it does it again. The bike is a 2012 GT 125r.
    • #5076
      Hey.
      I would start with the main thing (sometimes overlooked) is the carb.
      – Has it gone through a deep clean session (eg. Every single hole air blasted with a compressor and liquid cleaner)
      – has it had its floats messed with? (5mm instead of 7mm)
      – how the slide walls for diaphragm?
      – how are the diaphragm slides?
      – how are the main jets and pilots?
      – how OLD is your fuel filter (miles)
      – do you see particles inside fuel filter?
      – do you see particles in air filter and how old is it? (Miles)
      While at it.
      – how are the manifolds of the bike?
      – have the O-Rings of the manifold changed recently for fresh ones?
      – manifold clamps OK?
      – what colour is your spark plugs and can we see ? (To make better judgement too)
      What i have asked above directly affects your question. Each line of question should be addressed until your bike starts to run better. Because also what i said above can be repeated from the service manuals of various carby hyosungs.
    • #5553
      Matt
      Hi Marcel. Thank you for your reply. The fuel filter is about 200miles as changed it when I upgraded the fuel lines and the air filter is about 700miles. Both are free from particles. However the carb hasn’t been touched by myself as I’m not overly confident in touching the carb. The spark plug is quite dark black. Also the manifolds are okay, no leaks
    • #5554
      Matt
      Just noticed I answered my old thread. Today is not a good day.. this problem got solved.
    • #7729
      Max
      Hi Matt, how have you solved it?
