- This topic has 8 replies, 2 voices, and was last updated 2 years, 6 months ago by
♠️ M77.
May 6, 2024 at 9:12 PM #13303
AlexParticipantSo, recently I bought this bike and engine was dead so I decided to find another engine and did it
replaced engines and installed new one with 14k miles on it which was running fine on other bike and compession was absolutely fine
But I came to problem where’s bike jumping on throttle about 6-7k rpm
it doesn’t matter cold or warm it just how it is
im sure it’s carbs so your suggestions
what could it be?
one more time, as soon as I drop throttle off from 8-9k and give it throttle back at 6-7k it jumps like no power for second an then it catches
im assuming it’s air leaking or carbs not tuned right
May 7, 2024 at 7:56 AM #13305
AlexParticipantAlso just noticed another post about upgrading jets, if it could be a problem with this jumping on throttle
I got black widow straight piped exhaust and ktm air filter which also give more air
can it be jumping like that because of them two? And does it means I need to upgrade jets?
and if it’s possible what can I do temporary until I will get jets as I use bike daily to work and back
May 7, 2024 at 7:51 PM #13310
♠️ M77KeymasterKTM air filter ? Can you show us ? = I am suspicious on this area now.
Have you tried this mod below?
Exhaust = keep the baffle inside. It will help with backpressure a little bit as vtwins need it to get goin on the lower revs, so it should smooth things out a little bit , otherwise a missing baffle makes her loud but throttle feels too harsh. (it looses the crispy feel)
Jets = It could be why the last engine died ? , I would upjet the bike , here is a tutorial below
May 7, 2024 at 9:09 PM #13312
AlexParticipantOh sorry my autocorrect messed that up
k&n air filter
yeah I ordered baffle should arrive tomorrow
also jets and carb rebuild kit so as soon as arrives I’ll do all of the mentioned
one more thing I’ve noticed, if I’m doing cold start, it want me to turn the throttle 3-4 times so it can start (without choke)
Keeps idling fine on warm, but cold a bit hard so giving it a bit of throttle
aaaand, I know I shouldn’t do it but I did screwed in air fuel mix screws about 1 turn in and magic happened it’s not jumping on warm anymore but does on cold
last engine front piston and rings absolutely gone, I’ve opened it and was really surprised as it was just 9k miles
going to keep last engine for parts in case I need it
I will update you after my manipulations with jets and slide needle
May 8, 2024 at 6:59 PM #13318
♠️ M77KeymasterOkay fella, don’t touch it anymore and i would get fresh CR8E plugs from halfords , and take pictures of the plugs after a long run , just to make sure you are not leaning out! – Messing with mixtures would send you in to an abyss!
Defo avoid “IX-Blue Box” iridium plugs, they don’t like em. Stock CR8E or LASER is best for them (LASER is actually NGK’s preferred plug & is OEM to some Suzuki bikes)
May 9, 2024 at 5:55 PM #13327
AlexParticipantI got my old carb (looking better than new one) for ultrasonic cleaning today, and ordered new jets from jetsplus two days ago (not sure if coming and if it’s not scam as ordered with Royal Mail 24 and it’s been two days already)
as soon as jets will arrive, I will get it replaced on my old carb with carb rebuild kit I ordered here
hope all of this helps
(also I remember that air fuel mixture screws on them old carbs was 2.5 on front and 3 on rear, should I do the same when will get all ready?)
nice to have 2 engines (got every spare I need and can get them for cleaning while riding on main one 😅)
so yes, will get spark plugs as soon as all gonna be ready
May 9, 2024 at 6:12 PM #13329
♠️ M77KeymasterIf the jets don’t come, just message us and we will order directly from EBC ourselves.
2.5 turns each pot and leave it there forever (regardless of mods) 3 turns (ish) is OEM.
The slide needle mod has better effect than messing with mixtures.
May 12, 2024 at 6:24 PM #13372
AlexParticipantDONE!!!
Ultrasonic cleaning, and slide needle mod has helped me
still will put jets if they will come eventually, but yes it runs now like a new bike
total spent on bike from buying 1600~
and now it’s in the best condition with new michelin tyres on (from previous owner who was a twat)black widow exhaust (same from previous owner)
spare engine with blown front cylinder (oh yes)
and spare carb (dirty)
could sell spare parts if someone needs it (just give me a message here)
May 12, 2024 at 8:05 PM #13378
