Viewing 4 reply threads
    • #13325
      Alex
      So after a bit of ride on new replaced engine, can see it’s leaking from this seal (picture attached)
      where can I find this kind of seal? As found only on hyosupply, but don’t want to buy from there as already been aware of it
    • #13328
      Are you 100% sure it is the “clutch” arm itself that has a seal leaking out of it ?
      Not your valve covers dripping oil down ?
      Someone just paid for rocker cover gaskets , i am sure it is not you lol.
      If not,  send us an email and we will get a seal for you as long as we know exactly which one it is  in your email
      Contact
    • #13334
      Alex
      I’m more then sure that it’s not valve covers (I made some photos)
      If it’s not clutch arm then I don’t know what it could be honestly, but if there is a seal for this arm then it should be it leaking nothing else isn’t it
    • #13338
      Tell you what,  check the oil level when both wheels on ground and bike is 100% straight, give it a minute and tell us if its at the F mark or L- mark
      Clean the area,  run the bike for 5mins warm up,  rev it a few times , see if anything seems out of the clutch arm ?
    • #13346
      Alex
      Oil is on l level almost (as I’m waiting for 7100 delivery) so don’t fill it up at the moment
      ive done what you said and clearly seen like oil was soaking from that seal what I’ve told you, so now I’m 100% sure it’s that seal
      there was bubbles coming out and it’s wet in there, so means it’s coming out of there (not really much)
      I just want my bike to be perfect so still would like to change that seal (I will email you right now)
