oooooo, that’s a lot to take in.
How about this , disconnect all switches at the front (left & right ones) , clean them, and while at it, be sure the wire colours match the other end going to the harness.
You want to be sure the previous owner didn’t use a GV650 switch on a GT650, that has crossed or missing pins.
Switch gear out of the way, next stage is to check your harness for any signs of shorting……
GREEN WIRE + BLACK (2 pin bullet connectors for your turn signal lights) = is always the right side of the bike. = For indicators (Turn Signals)
Bulbs = 10w max (no matter what) , it must be 10w (not less, not more) exactly 10 watts ===> Each bulb for all 4 indicators (meaning you have 40w total)
The relay must be OEM = If its fishy , replace it and see if that helps.
LED indicators need LED relays = 99% of anything LED is made in china , so expect funny behaviour or be lucky you have a good set. I hate LED’s , so call me biased lol. I find the Halogen life easier haha or i’m just old!
Keep the tail lights UNPLUGGED (RED Brake combination tail & License Plate Illumination)
You want to be sure the Turn Signals work as intended , before pluging all other lights back in , otherwise we have tio start again from above ^ until a culprit was spotted.
You got this!
