- This topic has 3 replies, 2 voices, and was last updated 3 years, 12 months ago by
Mike Edmunds.
Nov 19, 2022 at 12:16 PM #9088
Mike EdmundsParticipant
cof
cof
cofI don
t know if Ive done this correctly! The lower picture is, I presume, the fuel pump. Can anyone tell me how it works?!! The top 2 are pipes which just hang down under the bike. Are they just vents? -
Nov 19, 2022 at 12:34 PM #9089
Mike EdmundsParticipantIn the 2nd pic, it is the thin tubing with the “T” connection that I mean.
Also, is there any way to test the pump (?) other than see if fuel comes out of the tube to carbs? -
Nov 19, 2022 at 4:06 PM #9093
♠️ M77Keymaster
FUEL OVER FLOW TO THE ROAD / GROUND
FLOAT BOWL MINI HOSES = FUEL DRAIN (To do this before removing carbs)
It dangles down to the road.See this link on how to drain fuel before removing carbs
Last picture…. FUEL PUMP yes correct 🙂“GREY PORT” = Vacuum input from intake rubber pipes.
“GOLD PORTS” ====> They have an arrow marked for fuel direction as you can see in the imageNow , please look at this tutorial below to help route the “fuel” pipes (gold ports only)
Please ignore the fact it is GTR 1255cc , it uses the same pump as a GV250 carby , Korea just moved the pump to another location
When the engine is cranking , make sure the fuel tap from your tank is switched on , and within 5 seconds (max or else starter motor overheats & more wear in the crank)
You will see the fuel shoot out of the pump in to a bucket when you point the hose down to it (the same hose that is meant to send fuel to the carb itself)Hope this helps ?
Nov 22, 2022 at 4:21 PM #9095
FLOAT BOWL MINI HOSES = FUEL DRAIN (To do this before removing carbs) It dangles down to the road. See this link on how to drain fuel before removing carbs
Last picture…. FUEL PUMP yes correct“GREY PORT” = Vacuum input from intake rubber pipes.
“GOLD PORTS” ====> They have an arrow marked for fuel direction as you can see in the image Now , please look at this tutorial below to help route the “fuel” pipes (gold ports only) Please ignore the fact it is GTR 1255cc , it uses the same pump as a GV250 carby , Korea just moved the pump to another locationWhen the engine is cranking , make sure the fuel tap from your tank is switched on , and within 5 seconds (max or else starter motor overheats & more wear in the crank) You will see the fuel shoot out of the pump in to a bucket when you point the hose down to it (the same hose that is meant to send fuel to the carb itself) Hope this helps ?
