    • #20669
      PaulGT250r
      Pulled the forks out to replace the seals.
      Ordered what I thought were the correct seals 41 54 11
      After removing the old seals found the size was incorrect.
      Old seals are NGK BR3976H
      Size is 41 53 8/10
      Anyone else come across this?
      Thanks
      Paul
    • #20673
      Hello, it is the correct size 11 54 11 as that’s what is sold and used in the UK , i personally not heard any reports on our soil such seals being missized.
      if the odd 53 size came on your forks (i wonder why!) , try to get that 53 size in your local seal stores. There will be something that uses a 53mm tube for hydraulics but i don’t have a reference to point to.
      That NGK part number seems to suggest also a 45mm seal used on Suzuki 200cc bikes , but can’t trust Google 100%
