Viewing 4 reply threads
    • #15600
      Alan McLean
      I’m sure this question has been asked on numerous occasions but I’m coming from a temperature view.
      I live in SE Spain where we have high temperatures most of the year so I’m wondering what is the most suitable oil for those conditions. My local motor factors of two types available they are Silkolene 10w30 Comp 4 XP and Silkolene 10w40 Super 4.
      Which of the above would be the best or should I be something other than those.
    • #15603
      Winter Time  (under 15 *C temps in the air) , basically cold days = 10w40 is fine. I would get Silkolene Pro 4 or Comp 4
      Actually find any oil that has ESTER  (that’s usually Silkolene Pro 4 or Comp 4) or (Motul 7100 , 300V)
      Fully synth is  best.
      10w30 is too thin, it will break down faster than a 10w40 would.
      Personally i prefer to use Motul 7100 at 10w50 or 10w60 all year round even on hot summers.  It’s “probably” the best oil for the hyo twins.  (Though the manual says use “more expensive oil if you can” to extend engine life)
      Why 10w50   (50/60 means it can break down less than a 40 grade)
      “10w” only  , don’t get 5w , 15w, 20w   ==== 10w is the perfect spot.   5w is like water.   20w is like sludge, too thick.  Stay on 10w(40/50/60)
      Silkolene Super 4 = Use this only if you can’t get the better ones  (Comp 4 / Pro 4)
      Hope that helps
    • #15604
      Alan McLean
      Thanks Marcel, very clear information.
      I think I will try and source Motul 7100 10w50 or 60, temperatures here in the summer are between 30° to 40°c so need the best protection possible.
    • #19851
      Cobra2
      Agree with 10W-40(or 50), but just as important; change it at least once a year, remember also the filter.
      BTW… does the GV250 have the larger oil-cooler (similar to the GT’s?)
    • #19855
      Agree with 10W-40(or 50), but just as important; change it at least once a year, remember also the filter. BTW… does the GV250 have the larger oil-cooler (similar to the GT’s?)
      Yes we recommend it to use on all 125cc. Their coolers are too small.  So 250 coolers are good.      GT250/GV250 use the same big coolers.
