Viewing 4 reply threads
    • #5523
      Ryan
      I’m having issues with my bike atm so when I’m riding along the engine shuts of and dies leaving me rolling to a stop I still have all electrical power no problems there if turn the ignition of and leave it for a minute it will start back up like nothing happened I’ve upgraded the fuel lines and filter to the one on the website so I don’t think it’s a fuel issue could it be the coils? It does bog when it’s cold, I’m thinking could be the cold weather as I finish work in the morning and that’s when it happens most, seems to be getting worse, any help would be great thanks.
    • #5530
      I think myself and simon have responded to this repeated post over at FB.  so if you can let us know how you get on?
      What you do may help others who are in this site too.  although my replies also benefit others. Its always good to share.
      Best of luck and I will ship your items shortly. Just waiting for snow to clear otherwise we cant travel on bad ice! (Almost slid today lol)
    • #5537
      Ryan
      Yeah I have just didn’t know how long this would take for someone to reply and I’ll keep people posted when I change them out thanks.
    • #7160
      Jez Boyd
      Hi guys. Just wondering if there’s any alternative coils for my gt125 comet? As I’m having problems with a weak spark. I’ve changed for new plugs and new carbon fiber ht leads and new caps but still not much difference. The battery is only 6months old too. So any pointers to help? Many thanks in advance.
    • #7162
      Did you get the new parts from this site or somewhere else ?
      How is the regulator ? How is the stator ?  = These 2 parts  (if not in spec by meter readings) will definitely make them weakest links for ignition systems and charging systems.
      Stator is part of sparking system due to the fact it supplies energy  (yellow wires) and communicates to the CDI how fast the flywheel is spinning etc  (blue/green wires)
      So the stator must output least 70v at 5k revs max.  80-90v is optimal.  Max is 99v. The korea OEM stators are infamous worldwide either 125 or 650 or 250, most owners upgrade them. There isnt much positives about them.
      Same goes for the regulators,  it is usually the 1st thing we change electric wise for something better.
      Reg will say 14v both idle and 5k revs  = any less than 13.5v  (whatever revs)  = must change. Manual also says this.
