Viewing 0 reply threads
    • #706
      Hyosung TE450S & TE450 Rapier Documentation
      The Hyosung TE450 Rapier (also known as the TE450S) is a high-performance sport quad that remains a fan favourite for its aggressive power delivery. To keep these machines on the trails, we have consolidated the official service manuals and parts lists below. These documents cover everything from routine maintenance to complex engine diagnostics.
      Technical Specifications & Maintenance Data
      The Rapier 450 is powered by a liquid-cooled, 449cc DOHC 4-valve engine. Known for its high-revving nature, it typically utilises a Mikuni BSR42 carburettor and a 5-speed transmission with reverse. Maintaining correct valve clearances and oil levels is critical for the longevity of this high-compression engine.
      • Engine Type: 449cc, Single Cylinder, DOHC, 4-Stroke
      • Cooling System: Liquid-cooled with front-mounted radiator
      • Braking: Dual front discs and single rear hydraulic disc
      • Drive: Chain drive with 5-Speed + Reverse gearbox
      Pro Tip: While the EU and US manuals share many similarities, it is recommended to check the EU manual specifically for street-legal lighting and wiring schematics.
      Note: If you notice any missing documentation for the TE450 series, please leave a comment below.
  • The forum ‘📥 Service Manuals & Owners Books’ is closed to new topics and replies.
