    • #20413
      songorng
      well today i turn that even if your bike is EFI, you still need to make sure the throttle body is sync. wow…… so.  there is a sync nipple that connect hose to sync on the carb version. but in EFI i see no nipple. only sensor. TPS, MAP, where to connect the sync tool? and where to adjust.
    • #20416
      The throttle bodies have air lines coming from the ISCV unit  ,  it is possible to measure how much air is being drawn on full throttle / half-throttle  , or switch of the bike with throttle closed , it is possible to measure if the throttle butterflies are fully shut.
      Also if you take off throttle bodies off and take sensors off , then pour a little bit of oil down there, and see if the butterfly leaks out  on the other side ?   = this isn’t fool proof, so it is just an idea!   = I did this on a row of carbs for Kawasaki ZZR , because i had to be sure all butterflies were equally opening and closing so each cylinder gets the same air flow.
