- This topic has 6 replies, 2 voices, and was last updated 4 months ago by
♠️ M77.
Jul 15, 2026 at 10:38 AM #22959
umitk11Participant
Hi everyone,
I’m putting my airbox back together and I have a quick question about the hose routing.
Does the crankcase breather hose connect to the front inlet (the one facing the handlebars) or the rear inlet (the one facing the seat)?
Thanks in advance for the help!
Jul 15, 2026 at 10:00 PM #22960
♠️ M77KeymasterThe black large pipes on your carb = They go to the road (0verflow / breather)
For general tutorial for routing fuel lines , see below
[How to Tutorial] Upgrade Fuel Lines & Filter on Hyosung GT GT125R GT250R (Carb Hose Diagram)
Jul 15, 2026 at 10:24 PM #22962
umitk11ParticipantThe black large pipes on your carb = They go to the road (0verflow / breather) For general tutorial for routing fuel lines , see below
thank you so much
Jul 16, 2026 at 9:31 AM #22963
Hi again
i cant find hose connection this topic
Jul 16, 2026 at 6:31 PM #22965
♠️ M77KeymasterThe black large pipes on your carb = They go to the road (0verflow / breather) For general tutorial for routing fuel lines , see below
Hi again i cant find hose connection this topic
Hello,
I am not sure I follow you ? The link is showing the tutorial how to connect fuel pipes from the Tank to the PUMP , then the carb
Your picture = Ignore the black pipe that is sticking out of the carb, just point it towards the ground (road)
Jul 18, 2026 at 8:09 PM #22974
umitk11Participant
this 2 nipple thank you for your help -
Jul 19, 2026 at 10:24 AM #22976
♠️ M77KeymasterAhh okay , i got you.
For each nipple, hyosung puts a clear cap called “Airbox Oil Catch Tank Cap” like you see #6-7 below
However it is not a part easily obtained on its own, so grab a clear hose and clamp it there , then block the other end of the hose and clamp it.
At least both holes will tell you if there is oil deposits inside the clear tubes (about 4cm long max is good enough)
Regards
