Viewing 2 reply threads
    • #7741
      Sam
      Hello can anyone show me the proper routing location for a clutch cable for my 2009 Gt125r I believe I may not have it on correct and seems to be very tight when I turn handle bars thanks
    • #7742
      Is the cable OEM  or where did you get it from ?
      The cable from the lever , goes under the key barrel, then it goes on the VIN  section under steering, then slide it down thru a /_\  triangle section of the frame on the right side , just as the same way the throttle cable is going down to the carbs.
      Make sure the “ARM” behind the engine is against the sprocket cover (this is Korea’s way) and it makes sure the clutch is fully neutral.
      Then finish adjusting it near the handlebar lever to have max 4mm freeplay before it starts pulling clutch.
      Please use OEM lever and OEM clutch mount. Every last chinese lever thats universal will guarantee the cable snaps. I don’t like them and another reason i don’t stock such parts.
    • #7743
      Also take pics and upload here, so we can see everywhere looks good.   (Engine clutch arm, cable,  the levers , how you have routed them etc) It helps a lot to see what the situation is like.
