Viewing 4 reply threads
    • #19586
      safaratrew
      Is there any olace where i can get new/used carburetor for gt 125 at reasonable price? Or maybe some substitute made of chinesium exists that will fit in this model? Im getting preety depressed cause i cant find any in normal price range
    • #19589
      I would not whatsoever use chinese carbs , many tried and failed.  If Hyosung had to use a carb giant like Mikuni Japan, then it’s £600 new that’s what Mikuni Japan would want hundreds , not Hyosung as they still have to pay Mikuni to make us a double carb specifically for the Hyosung 125
      What is actually wrong with yours ?  This site has every possible part to replace its internals,   all we need is your skeleton shell.
    • #19590
      safaratrew
      Skeleton shell is damaged/broken
    • #19592
      LaserBeam
      Is there any olace where i can get new/used carburetor for gt 125 at reasonable price? Or maybe some substitute made of chinesium exists that will fit in this model? Im getting preety depressed cause i cant find any in normal price range.
      Hi Safaratrew, i bought a Chinese Dual Carburettor for my GT250R. It’s called a PD26J. It’s a replacement Carb for Honda Rebel CA250 CMX250.
      It is almost the same as the Hyosung dual-carb but the throttle rotates the other way. So to fit it to our bikes we need to re-route the turn the bracket, for the throttle, around. I am hoping this will be easy to do but have not tried yet. The carb looks very similar. It is so cheap that there was no excuse not to try it. It cost me AU$65 (like 25quid). I may have to take the throttle bracket off the Mikuni Carb and swap it over, im not sure yet. Worth trying the PD26J i think.
    • #19594
      safaratrew
      Well i wold buy any that would fit even if i have to swap something inside it
