Viewing 3 reply threads
    • #2108
      shane
      how can I manually adjust the idle
      as the knob next to the clutch side will not turn freely ive tried to force it but turns back to where it was stuck
      my revs are hitting 1200rpm idle and need to adjust it
    • #2109
      shane
      Im going to try either tomorrow or sat when its dry is try force to turn it from where it connects to carb with pliers which im hoping this does work as I be out of options
    • #2113
      Remove the adjuster off the carb.
      Get some wd40 to soak for a bit , then  get mole grips
      Bit it hard , then turn left to force it to undo itself.
      The road salt / muck near the front is what causes them to seize. Not always easy to get on their own.
      Also,  get some ACF50  or grease –> spray in to it  ,   so that it will keep the area lubricated.
    • #2117
      shane
      hopefully it bloody stops raining later then I can attempt to sort it
