- This topic has 3 replies, 2 voices, and was last updated 7 years ago by ♠️ M77.
Aug 7, 2019 at 10:17 PM #3099
whyen i start the bike and try to drive it for a while on the road, the bike turns off, (not in the electrical way), and i am having problems starting it again. it happens most commenly in high speeds around 80-90 km/h. i have changed the fuelfilter, and sparkplugs. does any one know what the problem can be, and its not the fuel lines, i have checked them and they are fine. its a gt125r 2007-model
thx for answers
Aug 9, 2019 at 5:18 AM #3104
Hey,
What spark plugs do you have? Can we see them so I can judge if the carb is rich or not.
Spark plugs will also tell us if your ignition system is good.Just click “add media” above the reply box to add a few pictures in to this thread.
Until we get more info, your story is commonly:
– Ignition Coils.
– HT Caps
===lots of cranks ^ might mean weak sparking system.
===stock hyosung parts & HEAT = cuts off while riding , until something to do with sparking system cools down.If you are sure the fueling is good (eg. carbs cleaned out & good lines) , then look at the “Regulator”. It must say 14.6 volts at the battery , any less? = change it. 13.x volts is not good for these hyosungs.
===lots of SLOW cranks ^ might mean the battery is dying down and wasn’t being charged ==> also send less juice to spark your bike to life.Battery size is 12-14ah ( 14BS) . The speeds these bikes do when its healthy is usually 130-145km max
Aug 13, 2019 at 9:47 PM #3133
Aug 14, 2019 at 5:15 PM #3137
It would be easier to look at your spark plugs, take them out youself so we see what your engine is doing ?
CR8E is the stock plug thats correct.
